Ok I have a 91 xj 4.0 5 speed and a 90 parts 4.0 automatic will the alternator and starter worek from that one or are they difrent.could use the help thanks and how would I get a stuck pitman arm off tried everything I know shoot me sum ideas
If you don't care about the steering gear, heat, PB Blaster, and a pitman arm puller. If you need to reuse the box, PB Blaster, puller, and impact gun.
I've gotten them off with a pitman arm puller and heat. The cheap cast pullers (like I have) will break if you really reef down on them. Get it fairly tight (3/4 strength with a 12-15" wrench, and then heat with a plumbers torch (or better if you've got it). Some people have cut through them with die grinders. Obvoiusly, if you heat it all up too much, you can damage the steering box seal. I've been lucky in not having issues with that so far.
