DrMoab
- The Utah Backwater
K so I have my axle out and I've rotated the knuckles 4*. I need to adjust the upper control arms out to get my castor back to the proper angle. (My pinion needed to be rotated up 4*)
In order to not have to keep unbolting the upper arms I thought I would try a little simple geometry (give me a break, it's been 22 years since I used any in school)
It's 9.25 inches from the lower arm mount to the upper. So using my kids protractor I drew a line 9.25 inches long and then another line 4* off of that. I measured the difference at the top of the two lines and it came out 5/8 in difference. If I dial out my upper arms 5/8 of an inch that should get me in the ball park....right?
It's amazing what you lose when you don't use the skills they teach you in grade school.
