Hi Guys,
First time poster - I try to read posts as time allows.
I am getting a whirring/howling (insert your own sound effects here) sound from the distributor of my '96 XJ with the 4.0 HO. I first noticed it this morning and it went away after a minute or so. I drove to work and didn't notice the noise and all seemed to be
behaving as expected. The noise could have been there but I did not notice it over the road/wind noise. I went outside after work tonight and started it up - same noise again. The noise is similar to that of a bearing in a pulley going bad. I can feel the distributor vibrating if I put my hand on top of the distributor cap. I let it idle a minute or two and the noise would come and go. Once the noise stopped, if I would bring the revs up just a bit for a couple seconds and let it return down to idle, the noise would return. I pulled the dist cap before I left work tonight and both the cap and rotor look brand new still (I changed the plugs/cap/rotor/wires @ around 87K miles and it currently has 93.8K on it). There was no visible sign that anything is wrong from what can be seen by just pulling the cap and rotor.
Any thoughts on what would cause such behavior? Distributor need replacing? Oil pump? Note that the oil pressure has been fine and has not changed at all from normal. I would fix it myself if I was positive what the exact problem was..
Thanks in advance,
Rich
96 Jeep Cherokee 4x4 - Auto w/ 4.0 HO
3" lift w/ 31x10.50
North of Boston.
Thanks in advance,
Rich
3" lift w/ 31x10.50
North of Boston.
