- Michigan
I'm going though a 231 tonight and there's plastic ' spacer' or 'washer' inbetween the gears in the front of the case by the planiatary gears.
question is does this need to be there? It came out in pieces and was wondering if I put the case back together w/o this spacer would I be okay or do I need to get a new one.
I'm thinking that it was there for a reason, but then again so are the bearing that you don't use when doing a sye.
tia
tia
