DansGreyMj
- Nuevo, Ca
I recently converted my 87 Mj to an open cooling system when the radiator was punctured, the problem I am having now is that the heater function stopped blowing. I can hurn all the other functions to hot- a/c, vent, or defrost and it blows hot, but no air comes out when i switch it to heat. When i do turn it on I can hear it click on and hear some air blowing uder the dash just not from the vents. Prior to the swap everything worked fine, and the A/C will still blow ice cold. Anybody ever had this problem after a cooling swap? and yes i did swap in the control valve as well.
