Heater always on
Chico
Tijeras, NM
I am constantly getting heat, from the heater, coming in on the passenger's side. I am unable to turn it off. Any suggestions on what I can do to turn it off? Heater controls are all the way to the left. Even when the A/C is on I get heat. Any suggestions?
The valve is on the coolant hoses neer the pasenger side firewall. Early 4.0(87 to maybe91) has only 2 hoses as I remember while the later ones have 4 with a small vaccume line as well.
there is also a cable on my 93 that runs under all the ducting in the passenger side to operate a damper, it can get kicked and messed up.
be careful with that 4 way vacuum valve under the hood, it gets real brittle, mine busted. i replaced it with a barbed connector and a valve. turn it off in summer, on in winter.
