- Torrance, CA
Oh damn...
Background: So I got stuck in Bakersfield, overheating, was still running fine, just hot. I parked it and came back three or four hours later and had no power. I knew I had a slightly blown head gasket (HC in coolant) so that was the idea...
Today: I finally got the freshly rebuilt head on (mine was cracked, had to find another one), put it on, got everything buttoned up, took it out...NO POWER!
Same damn thing. It feels a lot like fuel starvation (about the same symptoms as when I had really bad leaky fuel injectors). Hesitation and no power on acceleration, lots of backfiring out of the intake (fore-firing?). The idle varies from smooth as silk to rough as my jeans after all day wrenching. A little bit of hesitation when gunning the throttle with no load, but none of that popping BS.
I pulled my fuel filter (bypassed it), that didn’t fix it. I haven’t checked the output of my fuel pump, but it doesn’t sound bad. The plugs are new, as is the cap and rotor. The plug wires are not new, but this problem happened VERY suddenly, in any case I’ll be getting new wires anyway. The intake and exhaust are both good, no cracks, and of course fresh gaskets all around.
So...any ideas? The only thing I can come up with is Distributor, but I don’t see how that can go from perfectly fine to perfectly screwed just because I parked it...
Oh, one more thing...I’m still running hot as well. Got almost to overheat on a simple test run this evening, ambient temperature was probably 65 – 70, no hills or anything, no AC. I just flushed everything out in my cooling system...
Frustrating!
Sequoia
Frustrating!
Sequoia
