J Rock
- Cypress, CA
I just wanted to post some information for future searchers regarding my experience with the harmonic balancer & belt noise / tracking.
Jeep: 2000 XJ 4.0, 84,000, Serp belt had about 5000 miles on it.
My problems were as follows:
1. Harmonic balancer seemed to have a SLIGHT wobble, it was very hard to conclude that this was factual even from underneath, it almost seemed like it could have been an optical illusion. It was NOT obvious like many other cases.
2. Second, the serp belt didnt track straight, the belt would move ever so slightly within the pulley system. The movement was the belt moving closer to the engine and then back away from the engine (still on the pulleys of course.) This occured in a rhythmic fashion...back and forth, back and forth.
3. Lastly, there was some kind of weird squeak going on with the accessory system, almost sounded like a bearing going out on the PS pump. The squeak occurred in a rhythmic fashion and seemed to be in time with the rhythmic of the belt movement listed in number 2. The noise was confirmed to be accessory related by removing the belt and running the engine BRIEFLY (dead cold, less than a minute) because the squeak was then non existent.
I naturally associated these three symptoms as one problem and assumed that the harmonic balancer must NOT be spinning perfectly straight, thus causing the belt to not track perfectly and in turn resulting in a belt squeak.
The only hitch to this theory was the fact that I thoroughly checked the balancer with a straight edge to try and see if any of the rubber portion was excessively protruding and could not find anything wrong. The pulley seemed extremely square using the straight edge. I did however notice small, TINY, cracks in the rubber. It was not something I would normally be alarmed about but considering the situation it gave cause to replace the balancer.
I used a factory balancer as I have head that some of the aftermarket ones don't fit quite right out of the box. I ended up buying my at the dealer for $100 because I needed it ASAP for a trip and they had one in stock, however I believe you can get one on parts.com for much cheaper.
NOTE: I found out at the dealer that XJ's make on or after (they dont know which) 2-11-00 have the new style harmonic balancer which does not use the "damper oil slinger." They no longer make the previous style harmonic balancer but provide a supersedence narrative for those switching to the new style:
"When replacing 33002920 W/ 33002920AB, tell tech to pull off the front cover and remove the damper oil slinger."
My XJ was made 2-14-00, so this did not apply to me.
The removal / install when quite well, I used the craftsman harmonic balancer / steering wheel remover and ordered a 1/2-20 4" long bolt with nuts from mcmaster.com to install.
After the install I put a new Gates belt on (I like Gates belts
) and started it up, all problems solved!
I noticed that the squeak was gone and that the belt now tracked straight (no movement.) I was also able to noticed that the harmonic balancer did seem to now track straighter, again it wasn't obvious.
I wanted to point out my experience because most of the information I have run accross leads you to believe that your harmonic balancer might be in OK shape if you dont have any rubber protruding and if there isnt an obvious wobble to it. Mine apparently needed to be replaced!
Pics of the old balancer:
