Hadfields XJ
xjtrailrider
Roanoke VA
$7000 obo (just a starting point) located in Roanoke VA. I'll help with delivery if needed. Not street legal in VA, but I do have a clean title for it.
This Jeep has gone everywhere its been pointed.
The body is rough as this has been a rock rig, mechanically its in great shape. Here is the build thread.
255k - 4.0
AX15 - 5 speed
NP231 transfer case with sye
I also have an uninstalled 231 doubler and a couple D300's.
Front Axle
HPD44 completely rebuilt 2 years ago. New everything except housing.
5.13 Yukon Gears
Lockrite
Alloy USA Shafts with Yukon Super Joint
Hydro Assist
OTK steering with 1 ton TRE's and 4130 DOM tierod
Diff Guard
Rear Axle
Ford 9" completely rebuilt 2 years ago New everything except housing.
5.14 Yukon Gears
Yukon Spool
Alloy USA Shafts
Traction Bar
GLO yoke guard
Suspension
4.5 Rockcrawler coils up front
Modified Ford radius arms with Johnny Joints
BDS Leaves in the rear with Deaver teflon spring liner in between each leaf
1.5 RE extended shackle
Beadlocks
36" TSL's front and 37" boggers in the rear. Measure to the same size.
Armor
Full Cage
Boatsides
Custom Front bumper
Tcase skid
Gas tank skid integrated into rear bumper
Rocker guards
Plated frame
Misc.
Herculined floor
Custom wiring for the battery/main fuse panel/starter and grounding
East Penn AGM battery top
AC works
External fuel pump
2 core high flow radiator
Also Included
Spare stock fronts with new joints
Spare rear shaft that is Alloy USA
Spare rear driveshaft
Misc small parts
Spare Warn Premium hubs
Fuel pump
I reserve the right to end this at any time.
Winch not included.
Just make an offer.
Call Matt; 540-525-1982
I agree, this is a hell of a Jeep. If I could afford a dedicated trail toy, trailer and tow vehicle, I would buy this myself! If you already have the trailer and tow vehicle then you are set!
Honestly, the drive train is worth every penny.
That name looks familiar.
Is that the guy you got me with to replace my CPS when I was to tired, to drunk and to cold to do it myself?
Nah, just drunk and lazy. :-)
