Hack and Tap SYE with the drive shaft
s7tech
I have a Hack and Tap I believe it is a Currie. It is what ever T&J sells and installs. I had a vibration that I could not locate so I replaced it with an advanced adapters sye. I am not sure if the vibe was in the sye or drive shaft because I replaced both at the same time and had a completely new drive shaft built. I have the drive shaft also. It was for a 5.5" of lift, and it should be a 23 spline shaft. It was in my 2001 automatic xj with a NP231 transfer case if that helps. Just so I am 100% clear if someone buys it, you could have a vibration when you install it, but I did drive it a while I only had the vibe at about 70mph and it was not that bad in my opinion.
$80.00
that looks exactly like the currie unit that was on my old case, I would say yes that is probably what it is.
