Guys runnin 36/37" tires (both w/ stockish and non stockish axles)
BIG98XJ said:
Yeh I`m only running 456s(perfect for 35s)little low geared for 37s but not too bad
Got pics?
I have pics of mine, but everyone has already seen them im sure.
If I were you, I would go with the rockwells, cage it, reinforce the frame, do whatever you need to do as cheapy as you can. $750 for a set is a deal I wouldn't pass up. besides, I've never seen an XJ on rockwells.
Sure it would be easier, but if everyone took the easy way out we wouldn't be where we are right now, would we. I know the XJ unibody is not designed for that much axle or tire, but you have to realize this is a guy running 36s on 4" of lift. The unibody wasn't designed for that either. Cheap seems like the type of guy who will push the envelope far beyond common belief, and do it right.
I'd like to see this project done just so I can learn something from it, as many others im sure. Plus, how badass would that be.
