Hallo. You can also change the senders. Oil pressure sender and temperature sender are different as the idiot light senders. Fuel and voltage, I don't know.
Willem's right. Change the oil pressure and temperature senders (simple on/off devices for idiot lights) to sensors for the gauge package. All of the other instruments will work.
[Edit] That is, as long as you get the right gauge package. IIRC, you'll need a 91-95 gauge package.
I just did this to my 91 xj yesterday. I found a set of gauges on ebay for $20. Then went down to the local parts store and got the new oil pressure sending unit and coolant temp. sending unit. Total for the whole job was $60. Better then you'll find at the scrapyard. The swap took about 20 min.
Here is the link for a great write up on changing them out.
