- Yucaipa, CA
Last night, I was messing around with my electric fan. I ran a wire from the fan to the fuse panel inside the XJ. I found an open terminal that was only hot when the ignition was on, and slid a male blade connector in there for my hot. It worked for a couple of minutes and quit. I later noticed that none of my guages work any more. All guages including tach and speedo. I checked all fuses at the panel as wall as the big ones under the hood. Don't see any that are bad.
Anyone know where the may be a fuse or fusable link for this?
Or even where the guages get their power from?
Almost forgot...96XH 4.0 HO AW4, full guage cluster.
TIA, Dan
TIA, Dan
