bdahlg
- Waltham, MA
Wasn't sure where to put this
91 4.0 aw4 short arm 4.5" w/32s
I'm getting a deep groan when I brake. It only happens at low speed (slowing for speed bumps ~10-15mph) and its definitely coming from the front somewhere; sounds more towards the driver side.
While going over the speed bump, I get an annoying pop-pop, one when I intially hit the speedbump,then the other when I go over the other side. Feels like drivers side only.
Having some death wobble issues also, only when I hit a bump with my drivers side tire while turning left. Doesn't do it any other time.
Have visually inspected numerous times while someone turning the wheel, replaced track bar with RE1600 due to play in frame TRE. No change.
The reason I put all three together is that they are probably related, since they all seem to be on the same side. I hate the groan, pop, and wobble. It's been a PITA trying to track the culprit(s) down and need your help!
Any ideas?
Any ideas?
