Muddy Beast
- WA
I had this problem awhile ago, pulled the starter, cleaned it, and reinstalled it. Well two weeks later after having no problems my starter motor seems to make a loud grinding sound like it's slipping or something while cranking. I can't figure out why but it's one of those "perfect storm" type things where it will only do it sometimes, but when it does happen I can stop cranking, try again and it will continue to grind till it finally starts.
The starter was new about 6 months ago, and the battery has 13-14 volts at all times. I searched but found nothing. Why is it grinding? And what is causing it so I can fix it?
~Scott
~Scott
