- Westminster, SoCal
OK, got some $$ that I didn't expect (not that much.... but it all kind of added up), so I'm thinking about going taller sooner then I thought I might be able to.
Anyways, currently I have 3.5" RE pack in the rear which sits at aout 4.25" ~ 4.5" without tools and extra junk in there (just the spare) and front is still the UC coils with the poly spacer. Also I got SYE so vibes shouldn't be an issue, and the shocks... well, I should be kind of ok in the front temporarily but rears should be fine for a while.
OK, so I'm thinking that the following might be my plan in order to end up with 4.5" ~ 5" (btw, I expect rear to settle a bit more, plus I expect to keep some of the tools in all the time so it'd be sitting lower from that as well):
RE1660 Extra H.D. Track Bar and the RE1665 bracket (btw, is there much benefit here over the standard RE1600 Track Bar?)
RE2700 1.25" lift Shackle
RE3715 Control Arm SF2 Lower ADJ
RE3780 Control Arm SF2 Upper Ft ADJ
RE1310 Coil Springs XJ 4.5"
Option two includes using the following as it comes in the 4.5" kit RE offers
CONTROL ARM SF2 LOWER FIXED 1
CONTROL ARM SR2 UPPER FT FIX
as I don't plan to go past 4.5" ~ 5" for a long time (famous last words? LOL) I know adjustable gives me more control... but...... $$
Potentially I'm looking to see if I can just relocate front brake lines (they seem awfully long for stock) or maybe get longer brake lines...... Btw, rear already has a YJ brake line so I should be fine on that. Also since I'm doing the arms, I might as well deal with the bushings
so I'm gonna order a set of front upper (axle end) bushings).
What do you guys think about this setup? Is there anything that I am forgetting or missing?? I know there must be... please point it out if you see it
