get more lift from a 3" lift
jeepgeek2002
Jax FL
mrscrawler has a RC 3" and the 32s are too big really..
what options do i have?
RC sells a 2" adjustable Shackle $50
BDS sells a 1.75 coil spacer..$39
can i use an aal on a 3" leaf pack?
Mark
just if you throw a puck and a shackle on it youll have to change the shocks... you can get away with factory LCA's up front but when i did it on the white one years ago i had to switch to an adjustable track bar... we could probably redrill the mount but that wouldnt be the right way to do it.... whatever you do dont put an AAL in the 3 inch pack
heres the old white one on 3 inch springs, 2 inch pucks, and 3 inch packs with a 2 inch shackle rinning trimmed fenders and 33 claws
Another consideration...find someone with 31s that might want 32s and swap!
Or find someone that's got a 4.5" lift wanting to go back down an inch or so and swap
i thinking about doing the puck up front and 2" shackle rear..
She wont give up the tires.. i can guarantee that..
Mark
avon got the cut.,. hell 34's fit on a 3" bb. mscrwlr might get Rusty's flares.. all depends on $.. but the initial $90 spending might be more in scope.
mark
