Cottontail
Three-De Off-Road
- Nashville, TN
Ok...so I have a new bucket list of things that need to get done to the XJ and I am working on prioritizing them based on how easy it is, and how expensive it is.
-I need to get new adjustable UCAs - easy and not too expensive (thanks to a Crawl raffle gift certificate)
-I need new shocks - also easy and a little more expensive
-I need to put an OEM steering box back in because I don't like the Durango one - again, pretty easy, and probably the least expensive yet
-I need to fix the gear backlash and set up in the front differential - way over my paygrade and, I would expect, not terribly cheap.
So, my question to y'all would be for a recommendation in the Nashville area to open my front axle, and correct the gears. Also, any ideas what I should be projecting for that type of fix? Lastly, I suspect I'm ok just going to a shop that I trust, rather than one that specializes in off-road. I mean gears are gears, right?
