bigalpha
Moderator
- Tucson, AZ
Is there a chart that shows which XJs/MJs would receive which gear ratio/axle based its options?
What if somebody removed the factory tow hitch from one Cherokee and put it on other Cherokee. Just by "looking", which Cherokee has a factory tow package (and potentially 3.73 gears) ?
There is no way to "look" at at an early Cherokee and decide its gearing. If buying (swapping, or installing) any axle, you should always spin the diff and count the tire revolutions, or open the diff cover and check the ring gear stampings to determine the gear ratio.
