tdsigmon
- Lincolnton NC
Would like a second set of eyes on my issue. My radio, gauges and odometer all went out in my 98 Cherokee
Previously my gauges would go out intermittently and a good smack would bring them back, no big deal.
So here's the current situation all airbag, check engine, check gauges, etc lights in the dash work. However all of my gauges (you know the things with needles :jester: ) do not work.
Also on an interesting side note my odometer was very dim without my headlights on. Radio gets power but doesn't work possibly unrelated.
Now things I have tried
-pulled dash and cleaned both plugs with dielectric grease.
-cleaned g103
-cleaned (a rusty corroded) fender ground
Some useful info I can't find in my Haynes manual or online would be at least the layout of the pin connectors on the gauges so I know what I'm testing, and even better would be if someone checked their resistances for the pins on the cluster or gas that info.
I know I'm asking a lot, but any help at all is more than appreciated. :dunno:
:yelclap:
-cleaned g103
