JT4Spencer
- Tehachapi, CA
- Warn 9000i winch 650.00 obo
- On board air sanden compressor and brackets, was installed and running when pulled off my XJ.
- Brand new autozone starter (trail spare), for 1996 XJ w auto
- Dana 30 front Alloy USA axles 30spline with warn hub stubs and 760 joints.
- Dana 44 rear Alloy USA axles 33 spline 5x5.5 studs.
- 3 straight white XJ doors. Missing pass rear
- Bilstiein shocks brand new in box, 5125/ F4-BE5-6250-T5 make offer
- Upper front shock brackets, seriously stout, ill have to send a pic.
- Daystar front ext bump stops, new in package
- Daystar 3/4" springs spacers (4) new in package
- AW4 trans pan
- 1/4" thick front lower control arm mounts, brand new.
- 1/8" plate front frame stiffener plates, brand new
- 3/8" rear leaf center pins, Rubicon express, brand new.
- 4 and 5.5 degree rear axle shims, rubicon ex.
- Silicone (black) upper and lower radiator hose set. brand new
- Lebaron hood vents
- Cap, rotor ,wires (all MOPAR) and champion plugs. Brand new
- Accel u-groove plugs. Brand new
- Rear floor mats (grey carpet).
- Exh manifold gasket (Brand new)
- Ball Joint press adapters, used once 90.00 new
Thanks
