live24wheel
- Phoenix
Selling the 8.8 out of my XJ. Going to 1 tons. Specs on it are as follows...
1998 Explorer 8.8, disc brakes, 31 spline.
Yukon Ultimate 8.8 Kit
Yukon Full Spool
Crush Sleeve Eliminator Kit
4.56 Yukon Gears
Ruff Stuff 8.8 Swap Kit (I will include the Spring plates and U bolts)
Ruff Stuff Diff Cover
Barnes 4wd Anti Wrap Bar Bracket
Fully Welded Tubes
Spydertrax 1.5" Wheel Spacers
The story behind the axle. I got it with 45,000 miles on it. I did a FULL rebuild, all new bearings, everything when I did the gears, axles, etc. It has had MAYBE 200 (two hundred) miles put on it since break in. It has zero issues and I have 100% confidence in this axle.
Contact me by text at 602-402-1326.
Yukon Full Spool
4.56 Yukon Gears
Fully Welded Tubes
