98XJSport
Destiny is the rising sun
- Western Maine
I have a 98 4.0 that I just did the head gasket on. During assembly I couldnt get my injectors to seal, so I had the fuel rail on and off several times. When I went to remove it the last time, I broke the second bolt in from the front off. Its too soft to twist with vice grips, so I was prepping to drill it and use a bolt extractor if I have one small enough.
Before I go out in the rain to do this, do all 4 bolts need to be used to hold the rail, or will it seal with 3? Or is that just asking for trouble as its obviously not a place where you want a fuel leak...
Thanks.
Thanks.
