01XJ... On my '98 5-spd....
Have worked on a whole lot of things out there so i am pretty much aware of quality that can and is being used in some vehicles. Is that some parts of these XJ's is pretty horrible, either through poor assembly, poor manfacture, or poor design. I can't help but to think is one reason they considered when deciding not to continue their manufacture.
As an example, at 60k miles the clutch pedal went to the floor leaving me stranded. Seems there is a small 'non-distinct' clip that is used to retain the clutch T/O bearing arm to bell housing. It had broken and the arm just eventually fell away. When replacing that clip i found the arrangement of the arm and pivot ball would not accommodate the clip properly!! No wonder it broke!! Had to carefully modify the arm and pivot ball to better work with that stupid clip. Whew!! Of course the dealer "was not aware of such a problem."
Then there is the speaker wire-in-the-door breaking problem. Seems there is this massive connector right at the pivot point inside that boot which focusses the bending of the wire to the point it breaks all the time.
When doing the Warn hub conversion at ~45k miles, one of the front axle u-joints was already dry!! The other one was close to dry. I am sure in short time if in 4wd in a hard turn that because the joint was dry, it may have been the cause of self distruction. Maybe could also be the source of vibration in a turn due to siezure. The new joints are end greasable.
Then there was the miss-machined axle flanges on both the front AND rear axles- D30 and 8.25. When taking delivery on my slightly used '98 with 38k city only miles, there was a slight rumble at 50 mph i detected on the 2 hour drive home. Turns out the u-joint cap saddles were machined too deeply in both the flanges to where the joint straps would not hold the joint caps tightly allowing the driveshafts to flop around. Was not a problem with the either the u-joints or straps. Due to the slop in the rear flange it wore the joint locating tangs in the flange on the 8.25. Replaced it when installing the Trac-Lok. The original straps were used and was totally tight. On the front axle flange, i surface ground the straps which then allowed adequate tightening- there had not done sufficient flange damage requiring replacement.
See?! Most of these should have been detected upon assembly or over time of assy. Is what appears to me as a serious case of "I don't give a damn." Is this total attention to detail that is possibly the main reason i had acquired such a decent and loyal customer base back in Va. Is just the way i am. Sorry 'bout that- Aaaand there is even more i could tell you about...... But, i still have and like this vehicle- nothing else like it out there.
