New 23 spline, long shaft, transfer case input gear. Takes wide bearing. This is the early gear cut that matches the early pinion gears. $40 and shipping is extra with cost based on where you are located. If you need it shipped, I will need your zip code so I can figure the shipping cost. I purchased this input gear from Parts Mike Inc. in 2009 for $93.24 when I was building a 231J based doubler to go between an AX15 and a 231J. It turned out that I needed a short shaft input gear to fit the AX15, so I never used this input gear. Email to [email protected] is the best way to contact me. Otherwise text or phone to 503-930-8393.
