FS/Trade Parts
Johnnie Walker
Piece of Fish!
WA state
Location: 10 min South of Pismo/Oceano Dunes. Central Coast, CA
In my recent search for matching gears to run in my new to me HP D30 I got a deal on parts and would like to sell/trade what I do not want.
First up, a Warn hub conversion. I believe it to be the "small" kit as I believe it has the 5x4.5 pattern, not the 5x5.5.
Included will be outer shafts, the hub setup with rotors and the lockout knob/cover.
I'll start with 225$OBO+ship
Next is a YJ D35. 4.56 gears, detroit full case locker, alloy shafts, new-ish drum brakes.
450$/OBO local pick up, parts train, or delivery for a fee of sorts
Possible part out for this if there is enough interest.
Yes, its a D35 that is not XJ specific. I don't want any comments about it in this thread. If there are any they will be reported.
YJ D30, disco-housing. Will be mostly bare and available after I pull the gears/carrier. Had one-piece passenger shaft, so the vac-actuator and such is not there. Will most likely have the knuckles still on it. And if purchased after I get gears swapped in my Hp D30, 3.07 gears/carrier will be available no extra charge. May even have some renix/small u-joint shafts available as well.
12-pack of Ballast Point Grapefruit Sculpin for this..
These axles currently have some sort of Coil spring conversion kit on them.
Appears that they utilize the leaf mounts as a base and the top plates that are shaped to the axle have u-bolts connecting them. There is also bolt-in brackets for track bars. All of the links (non-adjustable) are available, uppers have some adapter brakects for the frame side that looks like they use cam-bolts to adjust them. The track bars are also available.
Total of (10) links, here's the rundown.
(4) lowers (ft/r)
(4) uppers (ft/r)
(2) track bars (ft/r)
AS far as the uppers/lowers go, they appear to be the same length for front and rear respectively. The lowers have a vertical clearance bend in them, they look decent length (haven't measured any of them) But I guess the links could be potentially good for a "mid/long-arm kit" Maybe make them adjustable or y-link? Most of the bushings look decent.
Not sure what to ask on these. From the bit of searching on the interwebs for YJ coil conversion kits, they are pretty spendy. I would guess they could potentially be used for other applications as well.
Since I need a price, I will go with 300$/OBO prefer local pick up, parts train etc. Ship will probably be quite a bit due to weight, but if whomever buys them wants that then they can pay for that.
Trades I am interested in:
Good condition AX-15, 4WD trans. I would prefer external slave bellhousing.
Maybe NV3550 4WD.
MJ D44, 4.56 gears preferred
23-spline T-case, fully functional of course. 231/242/241OR
JK Moab wheels: good condition, no rock rash preferred. Really only need 1 or 2 of these for spares. But, let me know what you got.
WJ knuckles/steering setup.
Adjustable uppers for XJ/MJ
Reclining suspension seats. I'm kinda fat, so need something wide-ish.
Good shape MJ rear bumper, stock with brackets or aftermarket. Show me what you got.
99-up 4.0 intake manifold/ associated brackets for accessories.
HO stock air intake box
Let me know what you have to offer.
WARN Hub Conversion pending.
