FS: Pro Comp Xterrain Radial 305 / 70 / 16
stewgod
LA
Never used - $150.00 / Stew: 818/730-9490
  • 305/70R-16,Pro Comp Xterrain Radial
  • Load Range D
  • Max Load 2910
  • Tread Depth 16.5/32
  • Overall Diameter 33.1 Inches
  • Black SideWall
  • Sidewall Construction= DualGuard
The Pro Comp Xterrain's high void directional tread pattern takes over where other directional tires leave off. The Pro Comp Xterrain's extra thick side wall treatment helps resist scrapes and cuts, maximize a biting edge side wall for increased traction on rocks or in mud. Dualguard TM Polyester Body Plies consist of thick 2 ply polyester construction combined with a blend of dual side wall rubber allowing for maximum puncture resistance with total flexibility when using lower air pressure off road without excessive heat build up.
