FS: Jeep Cherokee JKS SuperNerfs & SBS and Kilby Enterprises Gas Tank Skid Plate
Mike L
Anaheim, CA
I have a new in box set of JKS Manufacturing OGS800 SuperNerfs for 84-01 Jeep Cherokee - $400
Per JKS:
Provides unsurpassed protection without compromising ground clearance or vehicle appearance
Unique twin-tube construction protects entire rocker panel and lower doors
Low-profile, round buffer tube allows vehicle to pivot around stationary objects
Mounts to vehicle using critical load distribution points enabling SuperNerfs to support the full weight of vehicle
Structural mounting arms made from heavy gauge steel secure JKS SuperNerfs to the vehicle chassis with four bolts each
Enables use of Hi-Lift® Jack on vehicles where OE bottle jack is impractical and ineffective
Primary support tube constructed of 2" square material with 0.188" thickness for outstanding load distribution
Secondary buffer tube features low-profile 1-5/8" x 0.140" round steel for excellent protection and clearance
Durable satin powder coat finish can easily be touched-up using common spray paint
Pre-threaded bolt holes on the back of each SuperNerf allow the primary support tube to be mounted directly beneath the body
Parts Included:
SuperNerfs - Pair
Brackets
Installation Hardware
I have a new in box JKS Manufacturing OGS962 Steering Brace System for 84-01 Jeep Cherokee and Comanche - $200
Per JKS:
Driver and Passenger Side
Rigid chassis plates reinforce most vulnerable section of chassis to prevent failure of vital steering function
Provides additional steering gear support necessary for large tires and off-road conditions
Ensures proper load distribution during winching and recovery operation particularly important on uni-body vehicles
Improves integrity of winch and bumper mounts, and strengthens and repositions OE tow hook provision for improved off-road clearance
Prevents the need for crude or expensive repair of steering gear mount common with failure on the trail
Replaces corrosive and failure prone steering gear hardware with quality, long-lasting materials
I have a new black powder coated Kilby Enterprises XJ-GTSP1 Gas Tank Skid Plate for 97-01 Jeep Cherokee - $250
Per Kilby Enterprises:
The Kilby XJ Gas Tank Skid Plate is made from 3/16” steel. The skid plate protects the rear mounted fuel tank better than the factory sheet metal shield, which is extremely vulnerable to rock impacts. The skid plate is designed to provide maximum clearances. The skid plate installation is simple using the factory mounting points and hardware. 100% bolt-on installation.
Located in Anaheim, CA 92808. Thanks for looking.
Re: FS: Jeep Cherokee JKS SuperNerfs & SBS and Kilby Enterprises Gas Tank Skid Plate
PM sent.
