FS 95 XJ 4.5" 33" 4 door $2200bo
flexin' xj
Holt, MI
Selling my '95 Cherokee
Green with Tan interior
My DD
4.0 Runs and drives fine
AW4
231
Odometer shows 200,000+ miles. I was told the engine had some work done at some point.
4.5" Rough Country lift with rear springs
Rustys adjustible upper arms
JKS disconnects
JKS adjustible Track Bar
JCR 1-Ton steering
33" Super Swamper SSRs 45-50% tread
15x10 American Racing wheels
Edelbrock Ceramic Header
Throttle body spacer
4 Hella lights on front bumper hooked to high beams
Aussie Locker in front - D30
Factory limited slip in rear - Chrysler 8.25
New front wheel hubs in the last couple months
Fenders cut
Rusty
Floor rusted
Rockers trashed
Roof above windshield had rust and started leaking. Does not drip, just seeps
Burns oil but doesn't seem to leak
Suspension pops at times. Don't know why
Rear spring bushings shot. Have new ones
Headliner sagging
Dents and scratches
Engine rattles. Possibly torque converter bolts
Neutral safety switch has intermittant issues. Won't start in park sometimes but if you put in neutral, it will start fine.
Interior smells musty from water soaking the padding from below
Third brake light broken off
Have extra set of 15" wheels with tires but tires are dry cracked and have slow leaks probably from the beads. Wheels were chrome but previous owner painted gray and the paint started coming off and I painted black.
Have extra 4.0 bored a little larger with comp cam and springs. Basket case. Costs extra if you want this.
I found a truck I want and need to sell this.
Can call at 517-290-7675
Don't know what to ask but I guess I will start at $2200 bo.?
New prices
$1200 without SSRs and Aluminum wheels
$1700 with SSRs and Aluminum wheels
Steering
Spare set of tires/wheels
Tire tread measurements in 32nds - 6,7,8,8
Re: FS 95 XJ 4.5" 33" 4 door $1600 b/o
Sorry. I am not ready to part it out yet. I have a truck in my barn that is where this would have to go to part out. Once that is gone, then maybe.
Thanks for looking.
BTW, New Price - 1600 b/o with current wheels and tires. $1200 b/o with other wheels and tires.
