Smithe1811
- NEPA
Ive gone back and forth on this alot and decided its time to sell,my third son is due in two months and aside from not being able to fit 3 car seats in it, i cant make enough time for it to finish the project.
88 swb pioneer, ba-10 that does NOT leak, 4x4, 6 cyl,d30/35 with stock 3:07's, factory rollbar, factory skids on the gas tank and t case, had factory buckets that i upgraded to the nicer xj seats with the big bolsters, full center console, cargo light, interior lights package, factory dash clock, ford 302 19# injectors, 1 inch throttle body spacer, rustys intake tube, sunroof, 4.5 inch lift, 97+ xj side view mirrors, h4 headlights with built in city lights. Extra stuff that comes with it that i havent installed(still new in boxes)-spectre cool air intake, pace setter header, daystar red superkit, clutch kit, engine and transmission mounts, floor pans, gasket kit, steel valve cover with the baffel, tail pipe, muffler, factory mud flaps. Other extra parts- bed, tailgate, tail lights, solid rear window(currently has the stock slider), tube nerf bars, rear bumper brackets, stock radio, driver and passanger side window glass.
Truck has a current pa inspection, however the stop lights and hazards stopped working, probably a bad ground or somethin stupid, was my daily driver until the stoplights quit a couple of weeks ago. Aside from that gremlin, the rear main seal leaks(comes with a replacement) floors are toast(comes with new ones), needs longer shocks and swaybar end links and needs the cad locked over(vacuum leak) The cab is solid as is the frame. I know i probably left some stuff out and ill add it to the list as i remember. Price is $3000.
