GAllgood
- St. Chuck County MO, USA
Relisting this, I am selling an 87 Cherokee Pioneer, pretty much all stock. Will not part out. 185k miles, auto, 605323 - 5 D35 Standard 3.55 gear. I actually have the build sheet, faded yellow Jeep paper with much of the info if anyone wants a code to see what other parts it came with.
My wife used it as a rural mail carrier for two years and I have driven it as an occasional daily driver.
But I have battled the Renix war and am giving up since it still gives me some drivability issues. It runs very nice with the occasional stall that takes it out of my daily driving routine which is what I want out of it.
Many new parts, here is a list -
New in 2007: Dynamax Cat Back exhaust, intake/exhaust manifold gasket
New in 2006: Radiator, thermostat, hoses, front rotors, pads, calipers, Rear brake drums and shoes, Tires, alignment with R.F. Upper Ball Joint, R.F. lower ball joint, front track bar, fuel injectors, fuel filter, Map sensor, Mass Airflow Sensor, Crank position sensor, EGR Valve, idle air controller, plugs, wires, ignition coil, vacuum line kit, and all relays.
Pics at: http://www.lvs.net/gallgood/
Resides in St. Charles County Missouri, just west of St. Louis.
$600.00
$600.00
