FS: (2) 96 Cherokees
Status
Not open for further replies.
XJsportG
SouthEast #4328 (RVA)
Richmond, VA
Posting for a friend, located in Richmond, VA:
Have two forest green Cherokees, both 96 5 Speed 4.0 4wd.
One was involved in a front end accident and due to repair costs was totalled. Has tan interior. ~167k miles.
The other was in a low speed side impact accident deeming it a total loss due to a small break in a weld on the passenger side. Rear door does not open, front does. Needs driver side door hinge. Air in clutch system so needs to either be bled or have ckutch master cylinder replaced ~237k miles
I am looking to sell both for parts, either seperate or together. Both would come with titles. Neither are driveable but both do start and run. Testing waters as of right now.
1932223_10152270065952930_2054253746_n.jpg 1898049_10152270066327930_936775842_n.jpg
Why isn't the side impact Jeep driveable?
Insurance claimed it as totaled because of a broken weld from the impact. Both jeeps still run fine. They are just "Totaled"..
The side impact Jeep will not shift into gear, possibly due to air messing up the clutch master cylinder.
The Front impact jeep has a flat front tire, and the fender is bent in so it rubs. He does have a full size spare he can put on it, and the fender should be able to be bent enough so it doesn't rub.
I'm passing this info along from my friend. If you want more specific details I can find out for you.
What are you looking to get dr the front impact jeep?
$1k but open to offers right now.
He ended up with letting the insurance take the front end collision one.
I'll be posting a new add for the other one and the lift parts he had.
Status
