5l33p3r
- Columbus, TX
hey guys, i'm putting my Jeep up for sale. i need to make room for other things and and figured someone here could use a new toy.
it's a 1995 Cherokee Sport: 4.0L engine, AW4 auto transmission, NP242 transfercase, high pinion Dana30 (non-vacuum model) in the front and a 29 spline Chrysler 8.25 (out of a 1997 XJ) in the rear. ring and pinion ratio is matched at 3.55:1
it has about 137,000 miles on it and i'd like to get $1,200 for it. i'm located in Columbus, Texas.
things to note: a couple weeks ago the transmission started acting up so after some investigation it was discovered the shift solenoids are bad (no big deal, i pulled the TCM fuse and just shift gears manually) the solenoid kits are less than $100 bucks on amazon and worked great on my other XJ so no reason this wouldn't fix everything on this one.
also, there are a couple minor holes in the passenger side floorboards from rust. (not bad enough for full replacement pans but wanted to mention it)
the jeep comes with a spare AW4 transmission and a spare NP231 (actually the shift solenoids from this trans could be pulled and swapped over if you didn't want to buy new parts), it will also come with the factory 15" alloy wheels and a kit of tintable raptor liner with grey tint that matches the factory grey plastic.
hit me up if you have any questions
thanks,
Travis
lift consists of the following:
rubicon express 3" coils
ironrock offroad fixed length lower control arms
ironrock offroad extended swaybar links
factory jeep JK rubicon front shocks with teraflex bar-pin eliminators
ironrock offroad 3" leaf spring packs
ironrock offroad adjustable shackles
kyb jeep MJ rear shocks with teraflex bar-pin eliminators
ironrock offroad t-case drop
tomken machine extended stainless steel brake lines front and rear
wheels and tires:
spidertrax 4.5-5x5 (XJ to JK) hubcentric wheel adapters
factory 2007 JK 17x7.5 wheels
285/70-17 Goodyear wrangler silent armor tires (load range D)
* spare wheel/tire is another JK17x7.5 with a 285/70-17 Goodyear duratrac
exterior:
front and rear fenders have been trimmed
front logans metal fab bumper
rear rustys offroad bumper
converted factory sealed headlights to 7" round trucklite LED
engine:
factory air box removed and replaced with AEM dry element filter
ironrock offroad 2.5" cat back exhaust
plugs, wires, cap & rotor replaced less than 5,000 miles ago
engine oil changed every 3k miles with 10w30 royal purple and wix filter
