GhostDakota
- Phoenixville, PA | Bethany, DE
First, the bad: Speedo gear needs to be replaced with proper teeth – speedo is not accurate due to this. Miles are actually higher as well due to this. Driver side rear wheel loses air pretty fast. The bead isn’t seating perfectly. Viking Wheel & Tire in Wilmington, DE can fix this for roughly $80 or so, or you may be able to take it to a local tire shop. Wipers don’t work perfect, but they do wipe. I think it needs a new spring. Headliner removed to prepare for T-top conversion. I think it actually looks good how it is, but the headliner (which is sagging) is in my basement if you want it. Needs two new o2 Sensors ($20 from Pep Boys, $75 from GM)
Here are the specs/info:
Year: 1993
Make: Chevy
Model: Camaro Z28
Miles: 145,000
Engine: 5.7L 350ci V8
Engine Oil: Royal Purple fully synthetic 10w30
Trans: 700R4 Automatic Transmission
Gears: 3.73’s
Locker: Auburn Posi installed in Collegeville, PA (I have the name of the place at home)
Rims: 17x9?” Cragar Bullitt Replica’s
Tires: 275/40R17 rear & 245/40R17 front Sumitomo HTR Z's with low miles – rears are newer than fronts
Paint: Hood and rear hatch are showing some signs of oxidization, rear spoiler needs paint (it’s new), rear “Berger Panel” is flat black In the Berger style.
Suspension: Factory
Fact Equipment / Accessories: Cruise, tilt wheel, power door locks, windows, power driver seat, cold AC, SLP Performance Camaro SS spoiler, rear smoked side markers, Hella 90mm projector modules (low beams) & Hella 90mm Free Form modules (high beams), Hella custom 12 gauge headlight wiring harness with relays and fuses, H9 HID kit with ballasts, ignitors, etc. Plug and play, no splicing was required, 160* thermostat, white face gauges, SLP Loudmouth Dual Exhaust with single 3" tips, Stainless Works 3" Y pipe, Moroso Cold Air Intake, Trick Flow air intake elbow, Parrot Rhythm n'Blue Bluetooth headunit, Rockford speakers, tuned at JS Performance in Hulmeville, PA, alarm system has multiple functions (normal mode, and an adjustable sensitive mode where certain vibration amount makes the alarm chirp or sets it off). I am sure there’s more that I am missing as well.
@ Cecil County Dragway (BEFORE the tune, on street tires and 93 pump gas):
Best 60': 2.091
Best R/T: .194
Best 1/8 Mile ET: 8.691
Best 1/8 Mile MPH: 81.05
Best 1/4 Mile ET: 13.475
Best 1/4 Mile MPH: 103.75
KBB VALUE stock: $3500 - asking $4000
Year: 1993
Make: Chevy
Model: Camaro Z28
Miles: 145,000
Gears: 3.73’s
Suspension: Factory
Best 60': 2.091
Best R/T: .194
