1998 XJ 4.0 with an auto trans Open frontend . Have XJ on stands wheels off brakes taken off .I can turn axel but left side is harder to spin then right !!!
You can remove the bearing assembly and rule it out. It should turn smoothly in the hand with light resistance. Replace both at the same time for best results.
