took my 97 XJ in for a wheel cylinder and rear brake replacement.
get it back from the mechanic, take it on the highway and its got a pretty good wobble up front from 60pmh and up, steering wheel shakes also.
didn't have the problem before so took it back to have them check it out. they re-balanced the front tires and found out the front 4wd u joints are worn out and a little loose. the balance helped out a little, the wobble doesn't start till 65 mph now.
anyone ever have the same problem of having a worn out u joint throw off your ride?
it makes sense that it could but wanted to check with you guys.
thanks
thanks
