front end vibration!
robert stalberger
vista, ca.
I read a couple of other threads on pretty much the same topic, but mine is a little different. i recently put a 4.5" rustys on my '90 xj limited and some 32x11.50 BFG mt/r's. i also replaced both drive shafts and all the u-joints and steering stabilizer. My front end starts vibrating at about 35mph and gets worse the faster I go. It's not the worst vib. I have ever felt, but i'm planning a trip this weekend up in the mountains and just want to make sure it's all ok before I go. Any advice would be appreciated since I only have a day before leaving.
I forgot to post that i have had my alignment done twice and my tires balanced twice since Saturday just to be sure.
Are your tires brand new or used? The first time I put a lift on my XJ I had 31s and I had a cord broken internally that caused it to shake... You cant check that on Balancing unless its checked on a performance balancer that will take the tire up to and past 55mph...
most balancer only go to 15-20 mph...
They are brand new and just got mounted on the rims and truck on Saturday. I had them put on at Discount Tire and i don't know what equipment they use.
I just had them balanced and rotated again today, and it seems as if the shake is still coming from the front right. It pulls to the right a little also.
tape. it seems like a faster and not as hard vibration as an unbalanced tire though.
Hey Robert,
When you put your front U-Joint straps back on the yoke, did you use locktite on the bolts, or have you retorqued them?
I recently did some front end work that involved dropping the front shaft. Later, when I put it in 4H, my front end vibrated like I was on a washboard road, at around 30 mph. When I looked at the front driveshaft u-joint by the pinion yoke, I noticed the u-joint had wormed its way up about 1/16" in the yoke, and that one of the 4 strap bolts was a bit loose.
This effectively threw the shaft out of balance. I removed all 4, applied a drop of locktite to them and all's well.
Hope it helps.
What's your pinion angle? What year XJ? Do you feel the vibration through the steering wheel or from below?
