kxfracer108
- CT
I have a long arm kit installed and I had to push my axle another inch forward. When I adjusted it I gave each sides Jonny joints a 1 inch turn each and when I checked my axle to see if both sides were even from center of front to center of rear the left side was a 1/4 inch off from the other side. I'm going to double check to make sure my steering is perfectly strait and that my measurements are correct but will that 1/4 inch difference be much.
The left side is 101 13/16 inches and the right side is 101 9/16
