Matt99XJ
- Ringgold, GA
OK here is what i have done to diagnose the problem.
I have a horrible hum/vibration over 65 mph. it gets worse the faster i go. The whole vehicle vibrates. It vibrates the change in the cubholder and the keys. It is a really low hum/drone.
I pulled the front shaft and it is almost gone but still noticable. You can tell it is coming from the front with it off.
1. I balanced the DS and changed all of the U-joints/Centering joint.
2. pinion angle is .5* below DS
3. pinion output has no noticable play in it.
What else should i check? Hub/bearings would grind right?
My tires don't balance very well, could it be them? The shake a little bit at 50-55mph.
