xj-grin
NAXJA Member #1096
- Colorado Springs, Colorado
Yes, this is on the WJ, but since my radius arm-style long-arm is pretty damn similar to what many of you are running, I think your 2 cents might be worth... IDK, 2 cents!
Symptoms:
*slight vibration 60-75
*Thumping noise over washboard-type surfaces -- not quite a clunk
*Flirting-with-but-not-death-wobble, particularly over expansion joints in the highway, etc -- as with all DW, sometimes it happens, sometimes it doesn't, but I am definitely feeling some harshness in the steering wheel that wasn't previously there...
Whats been done:
*nearly-new Duratracs mounted yesterday, bead-balanced by Joe :cheers: (the above symptoms were present with the old MTRs too...)
*new unit bearings on both sides;
*new TRE on drag-link axle side -- no evidence of play in the pitman side;
I crawled around last night trying to figure it out, and so far no luck. My wife did the steering wiggle while I watched the trac-bar, no play. I checked all the bolts on the control arms, no play. I took a pry bar to tall the johnny-joints and seemingly they are tight. The stock JK tie-rod is not my favorite design (bends forward at both ends to form a \____/ shape to clear other axle parts, which causes it to droop down on the TRE's from the wieght of the tie rod), but the joints seem OK...
I have not done ball joint tests as yet, nor have I had it aligned since I haven't done anything that could tweak the alignment... Thoughts? I'm taking the family camping this weekend, so I would prefer that DW not be in my vocabulary... If not for the wobble, I'd blow off the minor vibes and the thumping, I mean it is a jeep after all!
Pic of new-to-me-meats, just cause:
Symptoms:
Whats been done:
