I look under the Jeep yesterday and found that the front diff was leaking from the rear where the drive shaft is. Do I need to just replace a seal or is it much more than that.
Yes it needs a seal. The yoke needs to come off and the seal replaced. Air impact needed. Make sure you tighten the yoke down correctly depending on the gears you have, crush sleeve or no crush sleeve.
