Free hp cad D30
Outlander560
New York
Just like the title says free HP D30 with CAD (center axle disconnect) pretty good amount of rust on the coil mounts....the lip by the shock mount is rotted, not the part that the shock mounts to just that raised lip behind it. everything else looks fine.
Carrier, R&P, and driver side shaft not included....Passenger side shaft is included so are the knuckles and the calipers if you want them. Pickup only
FORSALE:
Stock shackles no rust used for 6 months then swapped out got them from team cherokee asking $25
97+ master window switch for drivers door..worked when I pulled it $5
Dorman DRL (day time running light) control modyle never used brand new in the box asking $30
HP D30 knuckles (not CAD) surface rust but in good shape $30
