Fox 10" Air Shocks
Stukboy
Lancaster, PA
Picked these up for a project and they are to small for my needs.
They are used and in good condition.
NO LEAKS!!!!
They are fully charged so you can install them and adjust down.
Features:
* Special "Smooth Bore" seamles alloy steel body
* Features a high flow,large bore,damping piston, and utilizes the highest quality valve shims available
* Nitrogen gas pressureized (Min:50psi & Max:500psi)
* Teflon lined steel spherical bearings
* Hard Chrome plated 1.25" 4130 Chromoly Steel Shaft
* Billet aluminum end-caps and eyelets
* Customer rebuildable and revalvable
Ext.Length:27.19" & Col.Length:17.19"
PLEASE buy them!!!
I would like $200 for the pair.
I can send pics if you like.
Stukboy
