Ford 8.8 set up for 4 link. All control arm, coil spring, shock and track bar mounts inatalled. All mounts are 3/16" 31 spline shafts and disk brakes. Will bolt directly into a TJ. If your planing on going long arm in the rear of your XJ so you can really flex, this axle is just what you need. It does need a carrier or spool and gears. $500 firm
Call Bruce 480-266-0642
all pm's will be deleted, you must Call Bruce.
Thanks
Dave
Thanks
Dave
