AZRockRunner
Nobody
- Tucson, Az
Ok Fellas, its out and under my carport awaiting for a new jeep to run under.
This is a Ford 8.8 out of a 2000 Ford Exploder with 4:10 gears and a track-lock limited slip. Has the M.O.R.E. E-Brake Cables included and has aftermarket perches welded on. Also has custom shock mounts welded on. This axle is XJ bolt in ready with disk brakes and calipers and rotors with plenty of life left on them.
I called around to a few scrap yards in Tucson and they are wanting 550 - 600 for a bone stock that must be fabbed to work under an XJ and they DO NOT include the disks and calipers in most cases. I am also including the Custom length U-bolts and 1/2" thick plates for them. Also included will be the adaptor from M.O.R.E. that will allow you to use a standard 1310 style U-joint and a standard drive shaft from a cherokee. Also included is a Rusty's Heavy Duty Diff Guard. This truly is a bolt in axle combo all you supply is the labor and the XJ...LOL
I am asking for 650 cash you pick up. I WILL NOT SHIP THIS AXLE so please do not ask.
And for those that are wondering, I am selling this becouse I swapped in a D44 under my rig since I will not be running anything larger than 33 or 34" tires on it. This 8.8 will easily handle a 35+ tire and not be a problem from what I have seen.
Lata
Lata
