KRIVRAQ
- North Jersey
1994 CHEROKEE SPORT
This XJ is completely stock. She has been driven daily, mostly highway for the past 5 1/2 years. And the concrete/asphalt jungle has become a bore. I think the trails are calling, therefore a rebirth may be in order.
Exterior consists of Dark Metallic Green with the usual minor defects: a few chips and scratches here and there around the bumpers and rocker panels; a few SMALL parking lot door dings--nothing deep, chipped, or rusted; rear bumper plastic corners are dented in--not cut or torn; Right front corner has MINOR, almost unnoticable, damage to bumper and fender (looks like previous owner may have slid into something, NO frame damage and hood lines are true); passenger side mirror has broken glass from ice hitting it from another car (I have the factory replacement, just never replaced--you know how that goes). All other glass is clean and functioning. All lights functioning.
Interior: Cloth/vinyl has some wear, could use a shampooing if desired. Carpeting is in good condition. Headliner in rear cargo area starting to sag (typical). All dash gagues functioning. Stock radio/cassette.
As for the "goods" :
This XJ is my fiancee's. I have performed all of the maintenance for her over the past 4 years and roughly 115,000 miles. My father, a lifetime Master Mechanic and multiple shop owner, helped with the tranny. I do not have the exact mileage quotes for all the maintenace I have performed, but here is a chronological list:
I will post new pics when the sun comes up!
Thanks for looking!
- 4.0 liter I-6 MPI 267,684 miles -- still VERY strong
- 5 speed OD manual AX-15 -- yeah! exterior slave
- NP-231 "Command Trac" transfer case -- 4WD works
- Power Steering
- Power Brakes
- AC -- not as cool as it used to be
- OEM Roof Rack
- 4 doors
- plugs, wires, distributor cap
- oil pressure sending unit
- starter
- clutch assembly, crankshaft rear main seal
- repaired surface rust (sandblasted) and pin-hole leak (JB Weld) under windshield top trim, new windshield
- front and rear shocks
- water pump, thermostat, serpentine belt
- power steering pump
- radiator
- catalytic converter (12.06)
- battery (2.07)
- 4 new tires (11.07)
Thanks for looking!
