truck7575
- georgetown
I am having to put my baby up for sale, this truck is a bit of a FrankenJEEP if you will. It is a trail MACHINE that you can drive to and from the trail, up any hill or through any hole and then drive it home and daily drive it. The Project was about a 2 year build for me that I did all myself. I don't really want to sell at all but i think it is time for a new project for me. See details below. I forget how to post pictures but they are available upon email request. The list of MODS is a mile long and I am sure i forgot a few but email me with any questions at [email protected]
Body: 1986 jeep wagoner VERY VERY little surface rust on body!!
Cut and folded rear quarter panels
Trimmed front fenders
Hood pins
Front Cage
Custom front Bumper welded into Cage
Rock Sliders welded to Unibody welded into front cage and welded into rear bumper
Rear custom wrap around Bumper with 3 foot unibody inserts
Metal Gas Tank skid plate
New style Cherokee sideview mirrors
Power Seats and windows
Drivetrain
Engine Bay
Dual Electric Fans with Summit Racing dual thermostatic controller
Brown Dog off road motor mounts
Oil Filter Relocation kit
2 gauge Complete Custom Grounding Strap Kit
1988 Renix Head
1996 Engine Block (4.0Liter)
AW4 tranny that has been rebuilt
K&N intake cone filter
Rusty’s Air tube
No exhaust leaks
ZJ Grand Cherokee Brake Booster, Master Cylinder and Prop valve
New style radiator with pressure cap
Front Axle
Solid high pinion Dana 30 with Aussie Locker installed
Axle tube seals
New Spicer 760x u-joints on 2000 Cherokee Shafts
2001 Cherokee unit bearings
4:56 Gears
Completely rebuilt with Timken bearings and new seals
Rock Crusher Cast Iron Diff cover
WJ Grand Cherokee outer C’s
WJ Grand Cherokee dual piston brake calipers and rotors
360 degree welded tubes
New ball joints
JKS Unit bearing Spacers welded 360 degrees
Bar Pin Eliminator Kit
Crown industry 5 Layer Stainless Steel Brake lines extended for up to 8 inch lift
Rough Country 4.5” lift springs and shocks
2.5” Spring Spacers
JKS Quick Sway Bar Disconnects
Custom Sway Bar Drop Relocation Brackets
MOOG Sway Bar bushings
JKS WJ steering setup including Adjustable Drag link, Tie Rod and WJ TRE’s with tie rod flip
JKS weld on extended sway bar links
All brackets Fully welded
Rough Country Control Arm Drop Brackets welded to unibody
Adjustable upper and lower Control arms
Front axle relocated forward about 2 inches
Rear Axle
Complete replacement Chrysler 8.25 axle from 2000 cherokee
1996 Grand Cherokee disk brakes and calipers
Aussie Locker
4:56 G2 gears
Rock Crusher Cast Iron Diff Cover
Complete rebuild with Timken bearings and new seals
29 spline axle shafts
Shaved Bottom Diff for ground clearance
Lower shock mount Mod to increase ground clearance
Bar Pin eliminator kit
Complete replacement 4.5” lift springs
2.5” Greasable Lift Shackles
Transfer Case
NP231 with slip yolk eliminator kit and replacement speedo gear
Replacement front and rear drive shafts with all new lifetime warranty autozone gold u-joints
Direct shift rod upgrade
Steering
Steering Box is a new stock replacement with very few miles put on it
Drop Pitman Arm (3 or 4 inch I forget and it’s either Rusty’s or Rubicon Express again I forget which)
Kevin’s Off Road Drag link Drop Bracket
Gauges
1988 Gauge cluster
SunPro Tachometer
Tires
-35 x 12.50 x 15 Goodyear Wrangler MTR Kevlar on steelie wheels 95-100% tread left no cuts or chunking
-35 x 12.50 x 15 Spare about 30-40% tread remaing (forget which brand acceptable condition for a spare)
Miscellaneous
-New fuel pump and sending unit
-Air condition/heater doesn’t work because heater core has a hole in it but compressor is good and you will get a used replacement heater assembly with good core in it
-complete set of doors come with it (was going to use to make half doors)
-Extra Hood
Additional Parts Not installed that are extra or for sale separately (make offer)
-Dana 30 inner C Gussetts
-JKS Lower Control Arm weld on Skid plates
-Rusty’s weld on top of axle tube Gussett
-Dana 30 Axle tube sleeves
-Bilstein 5160 front shocks for 6" of lift (part number available upon request
Asking $4500 Or best offer and Please email me with any offer on the JEEP or on the parts at the bottom of the page, these parts were meant to go on the jeep just never got around to it. If someone could remind me on how to post pictures I can def do that
Hood pins
Front Cage
Drivetrain
Engine Bay
1988 Renix Head
Rusty’s Air tube
No exhaust leaks
Front Axle
Axle tube seals
4:56 Gears
New ball joints
2.5” Spring Spacers
Rear Axle
Aussie Locker
4:56 G2 gears
Transfer Case
Steering
Gauges
1988 Gauge cluster
SunPro Tachometer
Tires
Miscellaneous
-Extra Hood
