Back when I first got the XJ I wired my 55W Hella 500's into the factory fog-light wiring so I could use the factory switch. That worked great for about three months. Now when I try to turn them on they'll stay on for only a couple of seconds then off again. If I wiggle the switch and hold it in the on position, but a few millimeters above the place where it normall rests when "on" the lights will stay on.
They have ground and power, as there are no breaks or corrosion in the wires...think I just need a new switch? Are these factory foglight switches prone to failure?
