- Curtis Bay, MD
Still haven't figured out the noise in my 4.0 but it's getting worse, coming in sooner, and sure as heck sounds like rod bearings. Loudest at no load and 1500 RPM (revving in neutral.) only 82K miles and I have no explanation for this as vehicle was well maintained but there you have it. I also crawled underneath it today and see that my oil filter adapter is leaking and my valve cover gasket is apparently pouring oil down the bellhousing (less than 200 miles since I had flexplate cover off and it's already coated/dripping.) Those aren't insurmountable problems but do add to the "what next?" factor.
I'm tempted to just suck it up and put a reman engine in here. What say you?
Damn thing runs great though and is all caught up on maintenance/fluid changes, plus I've already done lots of little "upgrades" to it so I'm already invested in vehicle. Rust free and drives nice, so I'm thinking it is worth it.
Alternative would be to just get some standard size rod and mains and drop the pan, install, hope for the best. Are the factory rod/main bolts TTY or reusable?
what say you?
what say you?
