Noodle5
- Smithtown new york
Where in an xj can I find 5 volts to run a set of lights off for the interior?
Use a 7805 voltage regulator. up to 1 amp at +5v might need to put it on a heat sink if drawing that much though
12v in 5v out
Here it is with circuit board/connections attached
http://numato.com/7805-5v-voltage-regulator-breakout-board
Google "7805 voltage regulator"...
